Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 11-05-2009, 06:01 AM
martinmdt1 martinmdt1 is offline
Question Won't start when warmed up
03' 6.0 won't start when it gets warmed up. Turns over fine, just won't fire up!! Starts fine when cold. Drive it 20 miles or so, shut it down and it won't start back. Wait 10 minutes and it will start after grinding the starter for an extended period. Anyone know what's goin on????? Thanks
2006PSDSD 2006PSDSD is offline
ΜΟΛΩΝ ΛΑΒΕ
HPOP seals
Old 11-05-2009, 06:13 AM
HPOP seals
What does the HPOP stand for?
Old 11-05-2009, 06:19 AM
ΜΟΛΩΝ ΛΑΒΕ
High pressure oil pump. There are some seals that like to go south on this, and they are located under the drivers side valve cover IIRC. Its pretty common, but I'm no tech either, just from what I've read here for three years
Old 11-05-2009, 06:20 AM
Dave Dave is online now
Obama sucks
Could be the STC fitting on the back of the hpop. Or could be the IPR
Old 11-05-2009, 06:25 AM
OK thanks a bunch
Old 11-05-2009, 06:40 AM
Snake Snake is offline
I agree that it sounds like the HPOP, branch tube, or STC fitting. Mine had similar symptoms and all three were replaced. Knock on wood, no more issues.
--Snake
Old 11-08-2009, 08:08 AM
STORMTROOPIN STORMTROOPIN is offline
if you had hpop seals going bad it would still start...??? im having similar issues
Old 11-08-2009, 08:16 AM
Maybe. Depends on how bad they are....
--Snake
