Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 11-03-2009, 06:34 PM
troid123 troid123 is offline
Send a message via AIM to troid123
Glow plugs not working/making noise first start of the day?
When I first go out to start the truck in the morning the glow plugs are not making their normal ticking noise. After the truck has been running for a bit and I shut it down and go to restart it, you can hear the glow plugs doing their thing whether the truck sits for 10 minutes or 8 hours. What is the deal?? The temps have not gotten any colder than about 40 degrees so I dont know what is going on. Can the relay have an intermittent failure?
Old 11-04-2009, 06:30 AM
Any idea's guys??
Old 11-04-2009, 07:01 AM
bockhold bockhold is online now
broke college kid
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
a 6oh has glow plug ticking?
Old 11-04-2009, 07:35 AM
BLACKANDTAN BLACKANDTAN is offline
in my 6.0 its the injectors ticking, try getting the pcm re flashed, if that doesn't work you might need the injectors flushed. good luck
Old 11-04-2009, 11:02 AM
But why would it only be on the first start of the day?
Old 11-05-2009, 06:36 AM
I sure would like to hear from some of the techs if you guys are out there!
Old 11-05-2009, 03:49 PM
Can someone please help me out?? The injectors are not buzzing the first start of the day, but they will every other time I try to start the truck through out the day. Why is this?!?? HELP!!
Old 11-06-2009, 10:22 AM
bump it up
Old 11-06-2009, 11:45 AM
DieselDano DieselDano is offline
That ticking you are hearing is the FICM(Fuel Injection Control Module) warming up the injectors. It basically helps the truck to not misfire due to lack of oil in the injectors and the oil being considerably thicker when it is cold. Your glow plugs wont make any noise themselves. Now, last winter there were a lot of FICMs dying due to the rapid heating of a 24 to 48 volt inverter inside the module. The usual sign was there would be absolutely no ticking at all, and the truck would either stumble, or not start at all. If you would cycle the key enough times, sometimes the injectors would start to work and everything would be fine, until the next cold start after a soak period. Is your truck running fine? The quickest way to tell if you have the latest calibration is to listen to the injector tick. If its just a steady rattle sound, that is the old calibration. If the injectors tick slowly at first and then click more rapidly, that is the new calibration, and you are hearing that inverter warm up more slowly, rather than immediately. It was done to prolong the life of the 24-48 volt inverter. When it dies, there is no tick at all when you cycle the key on.
Old 11-08-2009, 08:42 AM
Truck runs fine! Do you think the FICM is just about ready to quit completely??
