Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 11-02-2009, 11:42 PM
keroseneburner keroseneburner is offline
Constant knock. All else fine
Diesel gods. Searched awhile but no luck so sorry if I missed the obvious.
03 F450 w/ 91K. 6.0. runs good. Heavy truck but powerful. Starts fine. No smoke. Drove it 800 miles and got almost 15mpg-mainly highway 65-70mph. Big damn truck! No funny engine shaking. Revs good. Smells like, a diesel.
Problem-Constant knock. There on idle, more when it revs. Other than that it doesn't change. Only fix I have found is to turn the left nob on the radio.
New turbo recently installed. Dealer says #5 lost compression and truck needs new motor. Really? What do I do? Not as familiar as I would like with this engine. Run it till it dies? Don't want to do that but they quoted almost $19K for a replacement. ROTFL! Options? HELP!
Old 11-03-2009, 12:24 AM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
19K seems way high. im sure you can find a replacement motor, or have that one overhauled for a lot less.
Old 11-03-2009, 12:31 AM
shu873 shu873 is offline
hillbilly keyboard racer
Hell you could pay a shop to swap in a slightly used CR 5.9L for far less than $19k. You could also have the 6.0 rebuilt by a reputable diesel shop for far less than half of what Ford quoted you. It's not going to be cheap either way but depending on how trashed your current motor is you could be looking at $4-8k range on a rebuilt 6.0 and the labor.
on edit: I think you're located in Santa Rosa? Check out diesel nut motorsports in Sacremento. I know a few people who have had work done there and been very satisfied.
Old 11-03-2009, 01:33 AM
dannyboy950 dannyboy950 is offline
Man somebody is trying to get in your pocket. We buy brand new crate motors ready to plug in for less than 12k with freight included.
Old 11-03-2009, 01:22 PM
So...?
Well, I believe it. I will take the advice above but should I just drive it? It drives great! Noise is a bit annoying if the radio is off but only cause I know is shouldn't be there. Sounds like a cummins so I can get used to it. 800 miles and no change. will it blow up? COuld it just be a head issue?
Old 11-03-2009, 01:23 PM
Oh, and thanks for the replies.
Old 11-17-2009, 10:03 PM
Drove it -somewhat- loaded this weekend. 5 dirtbikes and 5 people. Drove it easy, hard hills and flats. Ran great! Noise there. Thinking i drive it until it blows? But then I'm on the side of the road. Not great situation. Could this noise be a head issue? Lifter? valve. What else taps constantly?
Old 11-19-2009, 06:03 AM
tkpatter tkpatter is offline
All of the above and more. The more you drive it the more damage you are doing. That iritating little tapping noise is most likly a hammer slamming away at your head or block. The most economical thing you could do is stop driving it and take it to a qualified diesel tech as soon as possible.you are doing more damage everytime you crank it.
