Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 11-02-2009, 05:45 AM
JamesFX4 JamesFX4 is offline
Engine has a miss to it
Lately when ever my truck has been sitting for a extended period like over night or at work it will crank and run fine but when you get to about half throtle it starts to missing almost like a rev limiter is kicking in. After its warmed up(10min) it runs like a champ? If I had a bad injector wouldnt it do it all the time? Any ideas???
No check engine lights are on either
Old 11-02-2009, 06:04 AM
Dan"gerous" Dan"gerous" is offline
Sounds like my truck. And yes I had Ford re-flash it. If anything it has gotten worse and takes longer to warm up since the re-flash. I should have left well enough alone.......
Old 11-02-2009, 06:13 AM
so what your saying is just deal with it? awesome
Old 11-02-2009, 06:20 AM
wriott wriott is offline
BUILT & BROKE BY ME
the best thing to do is have a buzz and cyl cont tests done... that will tell you what your problem is
Old 11-02-2009, 05:59 PM
ff524 ff524 is offline
missing
yeah my truck is doing the same thing... and just so happens that i have broken 3 rocker arms and thats what is sounds like. but also even at a idle. doesnt idle really rough right now but when i wake up in the morning and its cold it idles rough a little and works its self out...
Old 11-02-2009, 07:00 PM
did you find out the cause of the broken rockers??
Old 11-02-2009, 07:02 PM
the way mine idles when its cold reminds me of a SB chevy with a huge ace cam in it.. I lops pretty good for about 3 seconds and then its running like a top -the miss at RPM
Old 11-03-2009, 01:42 AM
dannyboy950 dannyboy950 is offline
Check each injector plug in wires for a loose one/ not fully seating. This can cause an intermittant miss.
