I started talking about this problem in a different thread, and I'll post a link to it. The problem I'm having is that my truck takes a while to start especially when cold in the morning. When I turn the key and she cranks it sounds normal except it takes between 5-10 seconds of cranking to get started. When she does start she immediately gets to idle and does not stumble up to idle. I was starting to think it might be my ficm going but from the research I've been doing it seems to be the beginning of the dummy plugs failing. (not enough to cause the no start while hot problem) So I've ordered them and will hopefully have them in by this weekend. I will post updates here on what happens and any input on what you think may be wrong is highly appreciated.
Sent from my iPhone using Tapatalk
