Need some Help in a Bad Way - Ford Powerstroke Diesel Forum
Old 10-27-2009, 02:38 PM
So took my truck to a diesel place. Not Ford bad idea i think. My truck passes all injector test egr ficm and everthing. Says nothing wrong with it and was there when he did it. It has to be an injector cause it has at least one cylinder down and misses horrible. Then one second you drive it it clears for just a while then back to crap. Thats my thought. So Im taking it to Ford now because they got to be able to do better test with there software and computer than that shop. That shop also said I had the latest update from ford for ficm tuning and not sure about that one. If anyones had the same problems or ideas Id like to here. Ford cant take my truck till next wednesday so stuck till then. Im going to do the injectors my self if thats it but don't no what it is.
Old 10-27-2009, 03:13 PM
check the connector to that injector it may not be fully plugged in or damaged.
Old 10-27-2009, 03:45 PM
ya thought bout that to but dont know which injector till I go to ford.
Old 10-27-2009, 04:11 PM
Just go check all the connections that go to injectors, including the UVCH.
Old 10-27-2009, 04:13 PM
Especially the UVHC
Old 10-27-2009, 04:20 PM
whats the uvch?
Old 10-27-2009, 04:25 PM
under valve cover harness
Old 10-27-2009, 05:02 PM
ICP will do that with out throwing codes won't it?
Old 10-27-2009, 05:12 PM
Go to a Ford dealer that can properly diagnose your problem in the time frame you are comfortable with. Unless you are in the deep woods you have a couple to choose from. Trust your tech to tell you the truth. They usually will. They just want to get paid for what they do. If you choose to do your injectors they usually have valuable info. Get to know them and make them your friends.
Old 10-27-2009, 05:19 PM
There aren't any under valve cover harnesses on a 6.0 but unless the shop has access to the IDS software then they do not have access to the proper means of diagnosing 6.0 injectors
