No start p2290 - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-27-2009, 11:53 AM Thread Starter
No start p2290
Truck just died going down the highway. Got it home and scanned it to come up with p2290.Desired ICP was 2480 psi, actual highest while craking was 437 psi. IPR duty cycle was 85%. Looks like hpop, pressure leak, ipr, or icp sensor right? Truck has 110,000 miles.
opel is offline
post #2 of 4 Old 10-27-2009, 01:21 PM
460+'s Avatar
Sounds like it, what year is it?
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #3 of 4 Old 10-27-2009, 06:43 PM Thread Starter
Its a 2003.
opel is offline
post #4 of 4 Old 10-28-2009, 01:19 PM
460+'s Avatar
Those are a pain to work on. The icp and ipr is under the turbo in the rear of the block. You will have to try to get an gauge to read the actual psi. Its a special thread and you can access it in the back of the motor. Theres a allen head plug that faces the firewall, there is sometimes a sheild you will have to take off. That is the test port I use to check psi at.
99 F350 4x4 dually
7.3 w/K&N af
4"lift &35" tires
D66 turbo
460+ is offline
