Dead Truck and codes? - Ford Powerstroke Diesel Forum
Old 10-25-2009, 12:42 PM
Unhappy Dead Truck and codes?
Ok, I have a 07 F250 Super Duty, 6.0 Turbo, 4 inch exhaust, K&N Box and filter, Edge Juice Attitude with Monitor, 42,000+ miles. Couple weeks ago, engine light came on, Juice showed code P0402 Exhaust Gas Recirculation Flow Excessive Detected, cleaned EGR, ran fine for about a week and then came on again. Cleared the code and if driving on the highway, no problems. If driving around town a bit, same code will pop up. Was going to clean it again but on Friday night after work, got into truck, turned on key and no glow plug light came on. Engine would crank fine but no diesel was getting in. Had it towed home, next day, noticed glow plug light would come on but had to jump start due to low batteries. Now the code news. Juice shows the following codes (in order, looked up some of the names on the WEB):
P0230 Fuel Pump Primary Circuit Malfunction
P0230 Fuel Pump Relay Driver Fail (This is from the Diesel code list)
P0237 Turbocharger Boost Sensor A Circuit Low
P0237 Turbo Boost Sensor A Circuit Low Input (This is from the Diesel code list)
P115A Low Fuel Level Forced Limited Power
U0105 Lost Communication With Fuel Injector Control Module
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
U0306 Software Incompatibility with Fuel Injector Control Module
Ran a diagnostics on the Juice Attitude and it has codes: P0004, P0008. Can’t find what these are.
Truck is now running but wonder if I need to take it to the dealer. Any suggestions?
