Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
  #11 (permalink)
Old 11-02-2009, 06:04 PM
lipps_03king ranch lipps_03king ranch is offline
yes before and after i cleaned the turbo the unison ring moved freely. The slots in the ring didn't seem to be worn out either, but i cleaned everything real good any ways and coated everything in a thin coat of anti-seize, and wiped them clean. yes i have an afe filter and airbox.
  #12 (permalink)
Old 11-02-2009, 06:57 PM
Gabe1911 Gabe1911 is offline
Hey- I have an 03 Excursion that I think might be having the same problem that you are. When I am driving it, I feel a loss of power and if I dog the crap out of it- it runs like **** the first couple of times I stand on it- then it will run like there is nothing wrong. But if I just drive it normal shortly thereafter the problem comes back. Does that sound like yours?
  #13 (permalink)
Old 11-02-2009, 07:59 PM
somewhat, but as it is acting up if i punch it it will downshift and spool up normal and pull hard. it seems to only act up when im crusing, or accellerating normal, not under hard accelleration. it doesn't drop RPM's much just turbo boost. and the problem is intermittent. didn't even happen the past couple days. ???
  #14 (permalink)
Old 11-02-2009, 08:20 PM
forddieseldoctor forddieseldoctor is online now
Powerstroke Techie
Did you check your exhaust backpressure tube and map nipple in the intake for restriction?
  #15 (permalink)
Old 11-03-2009, 03:53 PM
no i have not checked those yet, but that is now the next on my list, will get to it in the next couple days and post up the findings. Thanks appreciate the help.
  #16 (permalink)
Old 11-03-2009, 04:02 PM
elm302 elm302 is offline
where are those located at
