Ever since I bought my truck, an 07' F250 Harley,used, it seemed to take too long cranking before it would start. I took it to a dealer thinking the 100,000 mile warranty would cover it. Well, long story short, at first they said it was a bad battery, which I thought was ridiculous, and after changing the battery they said it was a damaged IPR sensor. The also told me warranty only covered the motor and not any sensors or anything, and that Ford would pay for half as a good will gesture. Anyway, paid almost 300 when everything was said and done. Well when I got my truck back it would
still crank too long before it would start. (I compare it to a previous 06' F250 I had stolen, so I know how long it should take.) Anyway, I decided I would keep using it like that, since I need it to drive to work everyday and couldn't afford to just leave it at a shop and be truck-less. Well yesterday, after leaving work, where it started as usual, I drove about 45 minutes on the highway and stoped at Wallmart to return a movie. I literally shut-off the engine for only a minute, while I left the movie, and came back out to go home. Well I was surprised to find that the engine would crank but would not start. The tank was almost full, I checked all obvious relays and fuses but could not find anything wrong. Does anybody have any idea of what could have changed after only a 45 minute drive and having shut down the engine for only a minute? Right now the truck sits at home until I can get someone to take a look at it. What do you think? HPOP? Crank Sensor? Any ideas or things I should check? This is my first diesel so I'm trying to learn as much as possible, but still not nearly enough to troubleshoot something like this. ![]() Sorry for the long post, but I'm pretty desparate. I appreciate your help, guys. Julian |
Do you smell fuel? I am having the same problem with my '04 F350 6.0. the only difference if that smelled fuel for a couple of days before and when it quit I popped the hood to find fuel spraying out of the top of my fuel filter. Changed the filters tryed to start if and no dice.
When you find out what happened to yours it would be great if you could post the solution. By the way what is the IPR sensor? |
first off to try stuff w/o a scanner. pull the fuel cap off (its the little plastic cap next to the plastic oil filter cap) have someone turn the key on and see if your pumping fuel.
next. if u can rig up a 5000 psi guage on a hydraulic hose pull off the IP sensor on the passenger side valve cover and get that thread fitting from any shop and hook your hose and guage to it. Crank the engine over like your going to start it. It should pump up to at least 1500 psi. try those 2 things if u can and see where it gets u. also you could have a FICM failure. which is Fuel Injector Control Module. Last edited by Ricemiester; 10-23-2009 at 12:56 PM. Reason: forgot something |
Nope, no diesel smell. I changed both my diesel filters a few hundred miles ago and my oil and oil filter about 3,500 miles ago. IPR means Injector Pressure Regulator, so I guess it has some sort of sensor on there. Maybe a tech can help us both out. I'll be sure and post if anything new comes up.
I think he previously had an '06 that got stolen... |
Thanks Russell |
They are located on the high pressure oil rails. To access requires removal of the valve covers, and a 10mm allen key to remove.
Okay,
I wish I had read this during the weekend. I cranked the truck over on Saturday, but not enough to try to start it, since the batteries aren't at their peak, after repeatedly trying to start it on Thursday. The high pressure oil leak is what makes sense to me, due to the long cranking time I was experiencing before this. Anyway, yesterday I got the truck on a trailer and towed it, with my ol' trusty 1984 Chevy Duallie Gasser, to a mechanic. He plugged in a scanner and, in less than a minute, told me the FICM was bad. I'll replace it and hope it starts right up. What do you guys think?? troid123: That was funny, lol, hahaha... no-tel-in is right, I previously had an 06', and it was stolen FROM ME! jajajaja I'll keep you guys posted on my truck's progress. Thanks for all of the suggestions, Julian |
