- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
UPDATE! Good News: The mechanic got the truck started today! He replaced the FICM, programmed the new one and the truck started right up! I think he also ran a full systems diagnostics and everything checked out OK. I won't know if it will still crank long before starting, but after a few days I'll post a further update and let you guys know how its going. Thanks for all of your help and suggestions. One curious thing is that my truck never missed nor stuttered on start-up neither did it puff white smoke while warming up, yet the FICM went bad without warning. Thanks again, Julian |
| Sponsored Links |
UPDATE! BAD news... My truck left me stranded again. :-( After starting up last Wednesday, I used it the rest of the week until yesterday afternoon when it did it again. I went to start it, about 30 minutes after shutting it off, and at first it stuttered, without starting, but that was it. Just cranking and cranking with no indication of it trying to start. This crank with no start was just what it did before the FICM replacement. I hope the new FICM is still good. Any ideas? I love my truck, but I'm starting to feel pretty frustrated with it... Thanks for reading, Julian |
My suggestion is to bring it back to the dealer right away. Park it, and hold the accelerator TO THE FLOOR for a good 5 minutes or so, revving the engine at 3900 RPM. Get it good and hot. Not shut the engine off, and try to restart it. Once you have the symptom present, bring one of the service personell out to show them, so that it doesn't get reported as a "no fault found". Get them to monitor the typical 6.0L no-start PIDs to see what's missing. Again, I put money on it, that you have a high pressure oil system leak as I already mentioned in my previous post in this thread. |
m-chan68, You were right. After leaving me stranded on Saturday, my dad went to the truck today and, now that its cold, it started up! Well, he'll be taking it to a dealer, not the same place where they replaced the FICM, so they can look for a high pressure oil leak. Apparently this will be covered under warranty, I hope, so we'll see how they do. They said something about pressurizing the system to look for the leak. Anyway, how much of a dis-assembly will they do to look for this leak? I know someday I'll probably wanna do an EGR delete, so if I can have the labor covered under this repair, it'd be great. Thanks again for your insight, Julian |
m-chan68, My dad drove the truck to the dealer, about a 1.5 hour drive, and when they shut it off, it started right up. They tried it a few times and each time it would start right up. They ran all of the diagnostics and all checked out ok. They let it sit for 30-40 minutes and again it started right up. I can't believe this! Anyway, my dad left it there. They will be removing the turbo in order to pressurize the system to look for leaks. If they can't find anything and the truck keeps starting up, I guess I'll pick it up and keep using it, worried about the next time I'll be stranded. Thanks, Julian |
Well, if they are "going in there", I would guess that they intend on replacing the STC fitting anyways, which to me is a good thing, given that it is a permanent fix to this issue. |
Okay, The dealer says they identified the oil leak and the truck will be ready for pickup tomorrow. Apparently, after pressurizing the system, they found one of the o-rings on the right side high pressure oil rail dummy plug was broken. They replaced it and were in the process of putting everything back together, when I spoke with the service manager. m-chan68, What do you think? Thank you all for the help and support. I hope my truck comes out running, and STARTING, good-as-new. jeje Julian |
| Sponsored Links |
