help!! problems clamping turbo - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-21-2009, 05:31 PM Thread Starter
i just replaced my egr cooler i've gotten everything back together but i cant get the exhaust manifold clamped back to the turbo anyone have any tricks or tips?? ive spent so many hrs on this damm clamp
ahren111 is offline
post #2 of 6 Old 10-21-2009, 05:57 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
Loosen the nuts and bolts that secure the y-pipe to the exhaust manifolds. With the slack gained by doing so, you can now move the y-pipe flange around just enough to be able to seat it properly to the exhaust inlet to the turbo and tighten up your clamp.
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #3 of 6 Old 10-21-2009, 06:04 PM Thread Starter
i tryed loosening everything, y pipe bolts, turbo bolts & the clamp from the turbo to the down pipe there's not much play in the y pipe is there any mounting brackets on it? i can pry it into place but it pops right back out & the only place to put the pry bar is where the clamp goes
ahren111 is offline
post #4 of 6 Old 10-21-2009, 06:07 PM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
If you can pry it into place, I would suggest having an assistant hold it in place while you tighten the clamp. Just be certain that the two flanges ARE properly seated before tightening it. Once tightened, tighten everything else back up.
m-chan68 is offline
post #5 of 6 Old 10-21-2009, 06:47 PM
Chapter Director
psd_va's Avatar
did you take the turbo apart at all? jsut curious if so make sure it is lined back up properly and make sure that the housing clamp isn't turned and hitting on something stopping it from sitting right. not really sure but jsut throwing some things out there
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #6 of 6 Old 10-22-2009, 06:13 PM Thread Starter
no i didnt take it apart. it weird almost like something is holding y-pipe everything is loose & the only way i can get it to move at all is with a really big pry bar
ahren111 is offline
