What do I buy ? - Ford Powerstroke Diesel Forum
Old 10-21-2009, 01:31 PM
What do I buy ?
Have truck at dlr, they're installing studs, egr delete under warranty.
I have read that oil cooler should be changed after egr/head gasket failure...
Dlr says O.C. is fine, but I'd rather start fresh with no EGR, and Coolant filter.
I see oil cooler housings and oil cooler kits on Ebay and the like, dlr says oil cooler is 300-400 from them, can I do better somewhere else ? Don't know what to buy.
Part numbers ?
Thanks.
Old 10-21-2009, 03:13 PM
Can anyone clear this up for me ?
Old 10-21-2009, 03:31 PM
Have you tried checking some of this sites sponsers? A number of them sell what you'r looking for.
Old 10-21-2009, 04:06 PM
You're very lucky the dealer is installing the EGR delete under warranty.
That's basically unheard of from what I understand, you must know somebody or have a very cool dealership.
Old 10-21-2009, 04:36 PM
No kidding where is that dealership located.
Old 10-21-2009, 05:00 PM
dlr is in northern NH, but my question still stands... which do I need ?
Old 10-21-2009, 08:14 PM
you can get a oil cooler (heat exchanger) for around $200-250. A whole oil cooler is around $500. The dealer should only ad an hour or so time to change it.
Old 10-21-2009, 09:37 PM
Thanks Miles !
Old 10-21-2009, 09:47 PM
If you egr cooler failed then the oil cooler should be replaced as well. I would replace it anyway and get a coolant filter to protect the new oil cooler.
Old 10-21-2009, 09:59 PM
Coolant filter from DieselSite should be here tomorrow.
Sounds like like I only need heat exch part of unit, see some on Ebay, but will ask dlr price tomorrow.
