What Head Gaskets - Ford Powerstroke Diesel Forum
Old 10-20-2009, 01:49 PM
What Head Gaskets
Lifted my heads last week my dealer will install whatever i want. I need some opinons on what to go back with, cause I dont wanna go thru this again also what should ask them to do other than fix it
Old 10-20-2009, 01:56 PM
arp headstuds
Old 10-20-2009, 01:58 PM
They'll install whatever head gasket you want or whatever head studs you want?
I'm not entirely sure about the 6.0s, but I don't think the head gaskets matter too much but the head studs are the important part.
Old 10-20-2009, 01:59 PM
arp studs and a egr delete
Old 10-20-2009, 11:00 PM
So the factory gasket will work as long as I go back with the arp studs? and should i get them to mill the heads or at least check them, or should they know to do all that?
Old 10-21-2009, 06:36 AM
Yes and yes
Old 10-21-2009, 06:46 AM
ARP studs and the factory headgaskets should do a good job of setting you up for success. Ask them to spec the heads to make sure they're still good. If they're not, see if they'll replace them rather than mill them.
--Snake
Old 10-21-2009, 08:51 AM
Thanks for the info guys
Old 10-21-2009, 03:35 PM
Were you by any chance asked by the parts person what gaskets you needed?
We have one here that depending on the build date we can have 2 different head gaskets for that trucks year model. One has 12mm dowels the other has 13mm dowels and the only way to know is pull the heads and measure em.
Old 10-21-2009, 03:52 PM
Not sure. My dealer is doin the work and the mechanic said he would install the studs for me while he was in there. I was only wondering if i should use aftermarket gaskets or just let them install new ford gaskets?
