Broken Down 6.0 Help please.
I just had my 04' 6.0 diesel break down on me.
Here are some the things that I noticed. -White smoke when starting -Ticking, over the engine sound I was cruising at 60mph when all of the sudden it sounded like someone through something into a fan, and i heard a lot of clunking. I immediately popped it into neutral and it died. When I finally pulled over and tried to restart, it would crank over and restart but it was really ugly and running rough so I immediatley turned it off. It is now sitting at a ford dealer where they ONLY tried starting it and said it was more than likely a bad motor. (10,000 new is what they said) Please help with any ideas... Thanks Jeremy jpope22@gmail.com |
How many miles? What kind of maintenance? Did you check the vitals oil? Coolant? Did you notice smoke towards the end?
The truck has 105,000 miles, the oil was a little low and I didn't check the coolant. No smoke that I noticed toward the end, only on start up, and when I would rev it. I kept the maint. up on the truck just put new air filter, but it was around 4500 since last oil change.
