White smoke and knocking! :( - Ford Powerstroke Diesel Forum
Old 10-20-2009, 09:46 AM
I have an '03 6.0L that only has 60,000 miles on it.
The other day, the truck lost power and was blowing white smoke. The motor started knocking, so I had the truck towed.
The white smoke smells like diesel.
The oil level is fine, but smells like diesel.
Coolant level is fine.
Truck starts, but sounds like knocking. Hydrolocking possibly?
Injector problem?
Old 10-20-2009, 09:48 AM
Good call on shutting it down, sounds like you've lost an injector tip
Old 10-20-2009, 09:57 AM
How can I figure out which injector went bad?
Old 10-20-2009, 10:13 AM
Hook it up to a scan tool and check for codes. It sounds like you have an injector stuck open. Just had a 7.3 in our shop like that last week. Sounded like it was ready to throw a rod it was knocking so loud.
Old 10-20-2009, 10:23 AM
Hooked it up already and no codes.
Also, yeah...it sounds like it's about to throw a rod. Loudest knocking I've ever heard form a motor.
Old 10-20-2009, 11:31 AM
Are you gonna try and fix it yourself? if so, PM me I'll help you
Old 11-20-2011, 06:38 PM
HELP
What was the out come of your truck im having the same issue i think it could be a bad o ring possiblly but not sure excatly what it is but have the same signs/symptoms
