What the heck is with this 6.0
Ok I was taking my brothers 05' in to get checked out because it has been smoking white on startup and also sometimes when it is warm. And I lookout the mirror and it is dumping out white smoke. I lost all power and it hardly idles. When i hit the throttle it spits and sputters and the white smoke turns to gray then black?? good thing tho he only has a couple hundred til the warranty is up! Any ideas just incase they try to jack us around? This is the first 6.0 in the family and nothing but friggin issues. I love my noisy 7.3!!!
is it puking coolant from dalgas bottle
I am no expert but I would say an egr issue or possibly a bad turbo. I am sure others will show up soon with more useful info.
Sounds like what happened when my EGR took a dump. If you smell coolant, then don't drive it or you could hydro-lock it and that is bad, bad, bad.
check for coolant around the degas res, my guess is headgaskets or EGR. hopefully not the latter.
i would have to agree with egr issues i would take off the egr valve only takes a few minutes and see how gunked up it is i usually see them stuck open you can usually clean it up with a pick and its good enough for a couple days the only other problem that ive seen alot is people go and buy the valve and in 2 weeks its gunked up again due to the egr cooler leaking believe me it gets messy and pricey
