Headgasket Leaking - Ford Powerstroke Diesel Forum
Old 03-07-2006, 04:35 PM
Headgasket Leaking
Can a headgasket be leaking bad enough to let air escape between the head and block? My truck sounds like a gasser missing a spark plug only not as loud. I don't think it's an exhaust gasket. Noise gets louder as rpm's come up and goes away until they come back back down to an idle. My wife said it was hard to start before this started today and seemed to be down on power. 03 F-250 6.0 Thanks for the help. Ryan
Old 03-13-2006, 05:42 PM
Sounds like you've blown your gaskets.....a common occurence on the 6.0L. Time to take it to the dealer (it is still under warranty?)
Old 03-13-2006, 05:45 PM
sounds to me like a leaking Y pipe to be honest or if it is a "squeeling" noise you hear as the RPM's come up....it could be a leaking EGR cooler gasket but i would still bet on it being a Y pipe.......either way...i dont think this is anythign to do with your headgaskets.........Marc
Old 03-14-2006, 05:06 PM
Truck has been at the dealership for a week now. And all they have said is it needs all four injectors on the left side. I guess it would be too much to ask that they replace all eight so I won't be without my truck next week when the other four die also. Thanks for the replys.
Old 03-14-2006, 05:08 PM
ford wont allow them to do all eight....if they do...ford wont pay them for the repair....its a catch 22....its not the dealers fault.......they are probably replacing one or two that are good as it is, its rare to have four injectors fail and have them all on the same bank.........Marc
Old 03-14-2006, 05:32 PM
I bank 6.0l everytime I replace one. I do this due to the fact Ford only pay to do the job once. It is very common to have a inj. fail on startup after replacing a inj. I did it Fords way till I had to pull one valve cover 4 times for one repair. On start up the next inj. in line would fail. I got payed to do the job one time, NOT FOUR. Yes, I did check fuel pressure. Yes, I did make sure I had fuel in the heads. Diesel repair does not count on your dealers 126 report. It shows but will not bring a audit. Next time your local diesel tech seem alittle short with you, remember he's the one fixing your truck and he may have just worked all day for nothing. Flatrate pay on 6.0l is a joke.
Old 03-14-2006, 05:33 PM
Power Strokeaholic
i thought flate rate was a joke any way.
Old 03-14-2006, 05:35 PM
you are not kidding there....on most repairs anyway......gotta love the time for head gasket repair......i can do it lifting the cab...but i would DARE anyone to do one in the cab with me watching and even come close to warranty time....SLTS is a joke and everyone but ford ISNT laughing......but i dont have to tell you.....you just gave me an excuse to vent ......Marc
Old 03-14-2006, 05:36 PM
Power Strokeaholic
breath,marc,breath.
Old 03-14-2006, 05:37 PM
Originally Posted by super_stroke
breath,marc,breath.
i have to remind myself that after every warranty 6.0 job i do bill
