need help from some of you 6 oh guys... - Ford Powerstroke Diesel Forum
Old 03-07-2007, 05:56 AM
Send a message via AIM to 96EDGEpsd
my dad just called me from work saying that there was a puddle of fuel under his truck on the passenger side(03 6.0 F-350 cc sb) , i havent seen it so i dont really know what looks wet or not...is there anything that i should look for in any specific area??
Old 03-07-2007, 06:14 AM
well, he just got home and i looked at it, it aprears that the leak is coming from somwhere in the area of the DRIVER SIDE exhaust manifold...seems to be right under it...??
Old 03-07-2007, 06:19 AM
your fuel lines run up in front of the exhaust manifold on a 6.0, to the upper fuel filter housing......then if anything up top was leaking on it...it would roll back down the valley of the motor and end up coming down the back of the motor in the exaust/bellhousing area....
first thing i would check would be the cap on the fuel filter up top....sometimes those o rings leak, especially if they dont get changed out when the fuel filter is done...
Old 03-07-2007, 06:41 AM
the filters do look a little moist, ill wipe it down and see if it gets wet again
Old 03-07-2007, 06:57 AM
a little more not so good info...i checked the oil and its a little past the full mark on the dipstick, it doesnt smell like fuel but its hard to tell...
Old 03-07-2007, 07:01 AM
ADMIN AND TECH
i agree with marc , dont think your problem is internal , if engine is runing fine
probably filter o-ring
Old 03-07-2007, 07:52 AM
yea it seems to run perfectly fine. it doesnt look like enough oil around the fuel filter to accumulate to anything....im letting the water dry off the garage floor(its snowing out) and im gonna try and see bettter where its coming from...
