burning coolant - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-09-2009, 09:54 AM Thread Starter
burning coolant
My truck is burning coolant ONLY when I hook up to a trailer. I would think if its head bolts it would burn all the time, or am I wrong? What else could be causing my problem?
'05 F350 Lariat FX4 4x4
8" Procomp Lift
37" Procomp X/T
Silverline Dual Exhaust
Looney tuned
smokin is offline
post #2 of 7 Old 10-10-2009, 08:05 PM Thread Starter
nothing???
8" Procomp Lift
37" Procomp X/T
Looney tuned
smokin is offline
post #3 of 7 Old 10-10-2009, 10:33 PM
metstroke06's Avatar
Sounds like definite head gasket issue. From my own experience and friends I know, coolant tends to go when under heavy load, either high boost racing around, or towing. My truck would puke coolant only when I would get on it, pull uphill or tow something heavy. If you are under warranty take it in, if not, take it to a trusted diesel tech close to you and install ARP head studs and all your problems will go away.
2006 F250 King Ranch
metstroke06 is offline
post #4 of 7 Old 10-10-2009, 10:34 PM
It could possibly be an oil cooler, but I highly doubt it. They will probably check the oil temps before they did head gaskets to make sure. You'll want to change your oil cooler when you do head studs anyway. Also, you should delete the EGR cooler. Unless you live in my state of California.
post #5 of 7 Old 10-10-2009, 11:08 PM Thread Starter
well sounds like what I was fearing. Guess its time to make an appointment.
8" Procomp Lift
37" Procomp X/T
Looney tuned
smokin is offline
post #6 of 7 Old 10-11-2009, 01:03 AM
Tennessee Powerstrokes
GoFastPadre's Avatar
ARP's and EGR cooler delete if it is on your dime. The dealers have stopped installing ARP head stunds, Ford has really cracked down on em'
To reach GoFastPadre
Official Chapter Area
GoFastPadre is offline
post #7 of 7 Old 10-11-2009, 05:59 AM
Powerstroke Techie
forddieseldoctor's Avatar
The most dealers will not delete the egr, but it's up to your dealer about studs, just ask them. My dealer hasn't said nothing to me about not putting in head studs yet.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
