Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 10-08-2009, 02:54 PM
scottf4444 scottf4444 is offline
Angry Blown Again!!!
WTF? Blown head gaskets again?!? I though I did the things I was "supposed" to do the first time...Head studs and EGR delete.
Now this one is out of pocket.
Any advice on any additional steps to take this time?
Can I reuse the ARP studs?
Anything else I should do while the engine is out again?
Old 10-08-2009, 02:56 PM
FionaThe02PSD FionaThe02PSD is offline
Have the heads decked by a quality machine shop. This is more than likely the problem and why you are replacing again.
Old 10-08-2009, 02:59 PM
RYAN SHAE RYAN SHAE is offline
Och man that sucks. Did you have the engine and heads decked? If not, from what I understand, Ford's talorances are very minimal at best. So you would have to have a machine shop deck them so that they are flat and true all the way and yes you can reuse the head studs. Thats not a problem. I think that decking the block will fix the problem.
mikeproc mikeproc is offline
Yes the heads need to be milled. They should be milled any time you take them off. I know there isnt a lot of room for play so have the machine shop make sure they are still within ford specs.
