P0299 After Cleaning Turbo - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-08-2009, 07:10 AM Thread Starter
2006 Ford 6.0L. Cleaned the turbo yesterday using the International kit and instructions, also updated the drain and supply lines to the updated Part #'s
Drain tube: 6C3Z-9T515-A
Supply line: 3C3Z-9T516-A
On the initial test drive, turbo felt like it wasn't boosting, very laggy (more than before the cleaning), and also threw a CEL with DTC P0299.
Is there a VGT re-learn that I need to do? Or what should I check that I am forgetting?
6oh Stroke is offline
post #2 of 10 Old 10-08-2009, 07:11 AM Thread Starter
Forgot to add, I understand that DTC P0299 is turbo underboost?
post #3 of 10 Old 10-08-2009, 07:34 AM
Powerstroke Techie
m-chan68's Avatar
Quoted: 3 Post(s)
How did the unison ring look? Particularly the cam pivot. Was it worn? How about your EBP/MAP/BARO readings at KOEO? What is your EBP reading compared to the other two? Did the symptom occur after the repair, or was it pre-existing?
Ford Diesel/Senior/Master Tech who placed 2nd overall in Ontario on the Fix-It-Right-First-Visit score for 2010
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....but STILL loves hot women with big boobies
....and STILL hates working on E-Series with 6.0L
m-chan68 is offline
post #4 of 10 Old 10-08-2009, 09:46 AM Thread Starter
Unison ring looked normal. Did not hook truck to a scan tool. Reason for cleaning the turbo was because of excessive lag. Truck has 150,000 miles with no prior service to the turbo. Symptom occured after the repair, no codes before the repair.
Thanks for the help
post #5 of 10 Old 10-08-2009, 09:54 AM
ajpu1983's Avatar
do you hear any hissing?? Check for boost leaks around intercooler hoses, y-pipe, and exhaust pipe
ajpu1983 is offline
post #6 of 10 Old 10-08-2009, 11:31 AM Thread Starter
It will boost up to about 23 psi at WOT, however off the line it has SERIOUS lag. Falls on it's face for about 4-5 seconds, then it spools.
post #7 of 10 Old 10-10-2009, 04:44 PM Thread Starter
Problem solved.
The anti seize that was used per International's instructions gummed up the turbo. Oops!
post #8 of 10 Old 12-04-2009, 03:09 PM
turbo
did you have to take it apart to remove the anti sieze or did the excess get blown out the exhaust?
PowerstrokeAaron is offline
post #9 of 10 Old 12-11-2009, 07:44 AM Thread Starter
I removed the turbo from the truck and disassembled the turbo, and cleaned it again.
post #10 of 10 Old 03-16-2010, 05:46 AM
do you have instructions on taking turbo out
wingnutt41 is offline
