Hi, I have a 2005 king ranch with the 6.0 liter turbo. The truck will only idle. There are no codes present with my cheap acutron pocket scanner. When i turn the truck off and restart it, the throttle will respond and it will function normally and wiil rev up in park. As soon as i put it in gear and put the pedel down it will cut out and just idle. The turbo turns freely and the exhaust is clear comming out. I have checked the fuses and all are good. Any ideas? I have looked at all the other post similar to this and no luck!
Need to get it on a good scanner. How many miles on the truck?
It has a little over 74,000 miles on it.
Take it in you still have engine warranty. The repair will cost you 105 bucks
Unfortunately it is not under warranty, it has a rebuilt salvage title.
Bummer. It was worth a shot. That being the case you need to get it on a good quality scanner that can datalog. Without that its hard to diagnose
It was the gas pedal.
your pedal assembly went out. It scared the crap out of me when mine went out doing 90 down the interstate
