Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 10-06-2009, 11:10 AM
TT_05_Stang TT_05_Stang is offline
04 PSD 6.0 started running bad, injectors?
So almost a year ago my oil cooler and egr went bad.
Now in the last 3 months on cold starts it runs rough until it warms up. It will miss a little and once it warms up it will run smooth, however it's lost at least 30% power.
I ran some lucas oil injector cleaner and it actually ran better and started better. Second tank of it it started to run worse again.
Second question I looked at my shop manual and it calls for 6-8 hours to fix an injector. How hard is it to replace?
Thanks for your help, I am just looking now at older threads to see if I can find someone with the same issue, and or you all have helped before.
Will
