Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 10-05-2009, 03:58 PM
RiverToyz RiverToyz is offline
2006 f-250 6.0 wont start
I have a 2006 f-250 6.0 diesel. It cranks but wont start. oil pressure gauge does not move. engine light on . last year I had problems with coolant leaking. took it to 2 different ford dealers they said head gasket was blown. then took it to a third ford dealer in Vegas it was cooler hose and some other valve they said. I don't have faith with the ford dealers. So I am little worried with this new issue. thank you for any tips or info.
Old 10-05-2009, 05:44 PM
T.R.P. T.R.P. is offline
HPOP..........
Old 10-05-2009, 05:59 PM
m-chan68 m-chan68 is offline
Powerstroke Techie
Does it fail to start when the engine is warm, or does it fail to start at all (engine warm or cold)?
Old 10-05-2009, 06:41 PM
dannyboy950 dannyboy950 is offline
M-chan has an important question there. I don't suppose ya have a scan tool that you could give us any codes or live data readings.
Altho with no oil pressure showing and assumeing the gauge is working I would suspect the low oil pressure feeder pump is not delivering enough oil to feed the high pressure oil pump to allow the injectors to pulse.
Just a thought tho.
