Loss of power intermittent when accel - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-04-2009, 10:24 AM Thread Starter
lipps_03king ranch's Avatar
Unhappy Loss of power intermittent when accel
Truck in question is 03 f-250 6.0 auto 4x4 132 000 Km. Have been reading all the old posts and searching on different forums for info on my problem. When i accelerate or am driving normal i get a loss of boost,or power with little to no drop in RPM, and get the flutter coming out the intake noise. From everything i have read, i narrowed it down to either the turbo vanes sticking, or maybe the egr valve being coked. So removed and cleaned the egr, it didn't look too bad, and also got the kit from IH and removed and cleaned the turbo as per directions. Coated everything in a thin coat of anti-seize and re-assembled and re-installed (the unison ring spun freely when i took it apart and didn't seem to be that rusted or carboned up). i re-set the KAM and truck was good for 2 days, now doing the same f-ing thing. The only thing left i might try is the VGT solenoid, But i hear they are quite expensive. Any suggestions are greatly appreciated. Thanks Dan.
lipps_03king ranch is offline
post #2 of 15 Old 10-05-2009, 02:40 PM Thread Starter
also the fuel, oil and air filters are all fresh. i am new to diesel's so any help would be great. Thanks in advance!
post #3 of 15 Old 10-05-2009, 04:59 PM
Chapter Director
psd_va's Avatar
were the turbo vanes on the intake side damaged in any way? and i have heard of throttle pedal do some funky things. hopefully a master tech will chime in
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 15 Old 10-05-2009, 06:31 PM Thread Starter
no, no damage to the turbo. everything spins freely and there was very little corrosion on the housing, and little to no carbon build up on the vanes and unison ring, but i cleaned them real good any way. i don't know if maybe the Injection pressure sensor is acting up? or the vgt actuator solanoid is messed up. i really have no diagnostic equipment to test these so just wondering how to tell what is wrong
post #5 of 15 Old 10-05-2009, 06:47 PM
elm302's Avatar
Feedback Score: 3 reviews
bud i am having the same prob took it to ford said my egr was sticking so i replaced it i also cleaned my turbo vanes and still doing im gonna pull my hair out i think its just about got to be a sensor or some electrical let me know what you find out and ill do the same
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #6 of 15 Old 10-05-2009, 06:52 PM
Tacomarunner's Avatar
MAP sensor?
O7 F-5504dr 4wd cab and chasis w/ 12' Scelzi service body 6spd manual trans. 200" WB 17,950 GWWR 4.88 gears
Overhead gauges w/ EGT and Boost. FCDP EGR Delete. AEM Workhorse CAI. Down pipe only, no cat or muff.
Tacomarunner is offline
post #7 of 15 Old 10-05-2009, 07:29 PM Thread Starter
possibly the map? i looked it up, it seems it is only a 30-40$ part, so it probably wouldn't hurt to pick one up. if it was faulty would it send the wrong signal to the pcm and then mess up the function of the vgt actuator?
post #8 of 15 Old 10-05-2009, 07:33 PM
Yes sir, it could.
post #9 of 15 Old 10-05-2009, 07:57 PM Thread Starter
cool thanks. i'll stop at dealership on way home from work tomorrow and give it a shot, is there a way to tell if it is shot.
post #10 of 15 Old 10-05-2009, 08:02 PM
That I do not know sir, I bokre the little nub off while I was doing GR delete. would not build boost with out MAP sensor being hooked up.
