- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Low compression on one cylinder.......
I did a compression test on my 03 6.0l and I have very low readings on one cylinder. The truck won't start right now so I did the test cold. Was getting high threes on other cylinders but one of them is 155 psi and when I squirt oil down that one it jumps to 175.
Think I have bad rings or could this be a bent valve?? I've only tested the drivers side so far as the passenge side seems very hard to get at.... |
| Sponsored Links |
Since you were able to increase your pressure readings by squirting oil in it. That indicates worn rings/cylinder liner. No change in readings would result if it was vaalve problems. Since most bore scopes are too big to fit in the glow plug hole or the injector hole,unless ya pull the tube. It will be hard to tell a valve without pulling the head. As to why,well a number of reasons could be why. Bad ring,ring damaged during install,or injector dumping too much fuel and diluteing the oil film on cylinder wall. |
i think i may pull the valve cover off mine some time this week or weekend and take a look for myself also. Ive been hearing a clatering noise.
| Sponsored Links |
