Oil Issue? - Ford Powerstroke Diesel Forum
Old 09-29-2009, 06:41 AM
Oil Issue?
I just changed the oil on my truck and the next day, the truck started to run like crap. When I turned it on the morning it started shaking real bad but calmed down within 5 seconds. After letting the truck idle for a couple of minutes, decided to drive off, but I didnt have any power. It felt like a had a couple of injectors missing and it would not accelerate at all. Decided to park truck and let it idle for about 10 minutes. Afterwards truck ran like a champ and for the rest of the day. It did this the next morning as well. Has never done this before. I have a 2005 F-350 with about 102,000 miles. I used Motorcraft oil filter with Delo 400LE 15W40. Also changed both fuel filters with motorcraft filters. Need some advice out of warranty and its real dangerous to get on the road because the truck doesnt accelerate till it warms up fully.
Old 09-29-2009, 09:26 AM
Powerstroke Techie
Get rid of that 15W40 oil and change it to 10W30 CJ-4 engine oil from Ford. Also check to have it reflashed to the latest calibration level if available. These engines like 10W30 oil better, which is why I use it all year round now on all oil changes that come into my bay.
Old 09-29-2009, 09:29 AM
OK thanks a lot. Could the weight of the oil be causing this problem or could it be something else?
Old 09-29-2009, 09:33 AM
Powerstroke Techie
These trucks seem to run better overall with the 10W30 oil. They start easier, warm up quicker during the colder climates, seem to get better fuel economy, and exhibit far fewer injector failures. Reflashing the modules plays a big role in the injectors' strategy.
Old 09-29-2009, 09:54 AM
Send a message via Yahoo to chuckles
question, is there a synthetic version of the 10/30 CJ-4 that you know of. Currently I'm using 5/40 mobil one synthetic and she seems to run very will with this. I tow pretty heavy loads sometimes, and the manual indicates to use 15/40 when towing. What is your experience with using 10/30 and towing?
Old 09-29-2009, 11:16 AM
Send a message via ICQ to VeeDubTDI Send a message via AIM to VeeDubTDI Send a message via MSN to VeeDubTDI Send a message via Yahoo to VeeDubTDI
From my experience with oils in diesels (VWs), a 5w40 has treated me better than a 10w30. Better cold weather start-up and better protection for the cam and lifters. Either way, a 15w40 is a bit thick for cold start-ups on the PSDs.
