Started having this issue last week and now it is considerably worse and almost undriveable.
Starts no problem. Engine sputters big time when accelerating and there is a lack of power. Boost gauge holds steady. Puking and going through a gallon of coolant per month. Was running Innovative’s Xtreme Street tune but returned it to stock and have the same issue. Livewire pulled codes: P0000, P1000, P0603, P132B. 04 6.0L – Build date per door vin sticker is 08/03. Head studs and EGR delete done about a year ago 80,000 miles Stock injectors, stock turbo Thanks! Last edited by scottf4444; 09-24-2009 at 09:21 AM. |
Sounds like you blew your gaskets again.
Thats what I was afraid of. And...probably a sticky turbo?
how is your EGR deleted?
A sticky turbo isn't going to make it run like crap and consume coolant.
With the EGR delete kit from Outlaw Diesel in Oregon - up pipe, coolant hose and block off plate.
ok, whats your oil temp vs. coolant temp?
I'll take it for a spin and check. Thanks for your help.
Coolant temp was 204*
I can't get an oil temp on the SCT Livewire. |
need to get a gauge or find someone who has a scan tool that can datalog oil temp..
