- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| Sponsored Links |
cylinder 8 is the driver side rear. The glow plugs are in the rocker boxes right below the valve covers. you can see the black wiring for them right above the exhaust manifolds. the secondary filter is the little fuel filter next to the oil filter housing in the center top of of the engine right behind the fan. There is a small allen head plug on the housing. You can remove that plug, install the adapter and then connect fuel pressure guage. |
ive been told that if you pull the glow plugs and if you find fuel or moisture on them you could have an injector problem, there is quite a bit of oil coming from around the #8 glow plug.... dunno. when im checking the fuel pressure what things should i be looking for and what is a good normal operating presure? |
if you pull a glow plug and it's wet with coolant, then most likely the glow plug sleeve is leaking. that requires a bit of work to replace. |
most of the simple scanners will only pull current codes.
| Sponsored Links |
