rpms up & down motor stalling - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-15-2009, 06:57 AM Thread Starter
Hi, i own a 04 6.0l my problem is that the rpms keep going up & down at all different speeds and stalls when turning corners or at stop sign's etc.My dealer has changed the e.b.p. sensor,high oil pressure pump & regulator,egr valve,& ficm it runs o.k for a little while when cold,then when it gets warm it starts all over again. There is no warning lights on the dash and every time i take it in theres no "codes".please can anybody give me some advice on this problem thx TREV......
trev07 is offline
post #2 of 5 Old 09-15-2009, 03:43 PM
ICP and Harness has worked for some with this issue. I'm dealing with it now myself but haven't dropped it off yet.
2004 CC-SB 4x4 King Ranch 8" Skyjacker 17" MT SideBiters, 37" MT Baja MTZ's, Road Armour front and rear winch bumpers, PIAA lights all around, Thule Racks, SCT Livewire IDP Tuning, EGR and Kitty Delete, Under Armour and Wounded Warrior Project Wrap
Turbo and Exhaust on Deck...
Ben
charkbait is offline
post #3 of 5 Old 09-15-2009, 05:59 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Sounds like your technician is throwing parts at a mechanical problem. Since it is a mechanical problem, you are unlikely to get any codes. Try to find another technician. Good luck.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #4 of 5 Old 09-15-2009, 06:55 PM Thread Starter
Hi,thanks guys for your advice,Ben you were right about the icp all those parts and it ended up being the harness for the icp sensor,lose connection replaced with new harness and now no signs of any of the problems i had before.I hope this helps anybody else out there with a similar problem
trev07 is offline
post #5 of 5 Old 09-15-2009, 06:58 PM Thread Starter
Thanks ben
Ben i took my truck in today and the problem was the icp sensor harness bad connection so they changed the harness $75 cad. I have had no further problems since then but its only been a day, good luck with your truck thanks ben.... Trev..
trev07 is offline
