VGT relearn?
i just did my egr delete yesterday and now the boost isn't right how do i do the vgt relearn can't find anything that seems to work.
what do you mean your boost inst right, whats the truck doing? There is no such thing as a VGT Relearn.
it seems as if the veins are not moving. i have been told and read that for the 03's there is a relearn process for the vgt solenoid.
not that I know of, if the veins are sticking, you can try to free them up by running it hard a few times..otherwise you will need to pull the turbo and remove the rust from the veins, as that typically is what makes them stick.
I did that while it was out for egr delete
there is a boot barb on the actual intake manifold(its brass) remove the hose from there and stick a paper clip (or something small) thru that barb and make sure that there is no debris in there, if there is, there will be no boost.
The one passenger side with coming to the side
yes on the passenger side of the manifold
Any body else have any ideas? Please I can get the vgt to relearn
There is no vgt relearn. I have done this and it works the same after as it did before. But make sure you have the boost sense line hooked up ( i made that mistake on the first truck that i did!!) It would not make any boost. Other than that the only thing else is maybe you put the vanes in your turbo the wrong way?
