small oil slobber at charge air cooler - Ford Powerstroke Diesel Forum
Old 09-14-2009, 05:27 AM
Good Morning,
I have seen some evidence of a small amount of oil/blackness at the connections from turbo outlet to charge air cooler tube. How much if any should be considered o.k. ?
thanks
Old 09-14-2009, 05:44 AM
It is from the crank case vent. Some see more than others. One thing you may try is to pull the tubes and the boots and clean it all real good. It helps to take some sand paper and just scuff the tubes a tad where the boot slides over. Reinstall and you should be fine. One thing you can do which is not nessasary is a CCV mod which basicaly rerouts the vent else where and drips oil. or you can rerout the vent thru a canaster than back thru the intake.
Old 09-14-2009, 03:43 PM
Thanks alot for the input...had the truck under 2 weeks and still learning the ins and outs of it.
Old 09-14-2009, 06:02 PM
Send a message via Yahoo to chuckles
There's lots to learn bout the 6.0!!
Old 09-15-2009, 05:20 AM
I am finding that out!!
