HELP! ~ 1 month warranty running out
So if any of you saw this thread I was very happy for about 18 hours...
got my man card back I've got about 120 miles on her now and now have a surge when stopped on the road and the turbo will also spool unnecessarily on the highway when surging. It also just about conked out when stopped in between surging. Luckily I have 30 days 3,000 miles to work a lot of this out. So to you experts of the 6.0, please help me fix my ride. I've done some searches have come back with the all too likely suspects, the EGR valve/Cooler and possibly the Injectors. I will be taking it to the dealer to exercise my warranty but would like to go in with a targeted list. The idea being that we can fix one thing and move on to the next and so on until my 30 days run out. Also, if it is EGR Related has anyone tried the bulletproof EGR or is a bypass a better bet? I'm thinking I'd like to stay legal but want to be as reliable as possible so a delete may be in the works. I'm assuming it will not pass emissions in MD without the EGR? Thanks in advance for the help guys, this site rocks! I don't want to return or regret my decision. Last edited by charkbait; 09-09-2009 at 02:39 PM. |
If you decide to keep the EGR the bulletproof piece is a great choice. If you go the delete route go with the First Coast Diesel Performance kit
This is not to say that I don't want to see you get anything and everything addressed on your truck before your warranty expires, and it's a very nice looking truck by the way. I am just hoping that this post will be a very strong reminder that it's NOT up to the tech doing the repair in the end. Quote:
appreciate the feedback!
To be clear the dealer (Honda) I bought from would cover the work at the Ford dealer, I just want anything that could potentially go bad to do so in the next month while I'm covered. What are your thoughts on the ICP being an issue? Am I better off dropping it off or taking a list like this for them to run through (feedback appreciated on this as well) ICP EGR valve VGT or other turbo IRP Injectors Or just show up with a detailed description of what is happening? Thoughts from a guy who deals with internet no nothings like me all day? It will only do it when pretty warm, just want them to be able to recreate it and get after it. |
I also want to add some symptoms from the way home this evening which may lead us away from the turbo.
The truck had a very hard time settling back into idle if that makes sense to the point of almost turning off in my driveway when I got home. It would also have a hard time while underway but off the gas and would eventually settle back into that wonderful diesel cadence. I did some searching and similar symptoms have been solved with an ICP and harness but want to hear everyone's thoughts. So I have surging and what I would define as a pretty rough idle. Should I push to get re-flashed as well? |
Is this an early-build or late-build 2004 model year? If your truck were to darken my doorstep, I would be running an Air Managment test as well, to determine EGR flow and operation. If this truck has idled extensively, or been subjected to very short distance drives, I wouldn't be surprised if the intake manifold EGR passages as well as the EGR valve itself, would be plugged solid with carbon.
I almost died after reading your signature... I know someplace I'm never moving
I would think, the surging is egr valve, try unplugging it with the key in the off position.
see if the surging stops. maybe tap on it a bit to make sure its not stuck. The put the key on and off a couple times. When you unplug have it in the off position or key out. |
appreciate all the response and will get to some amature diagnosis soon, no issues on the 30 mile ride to work today.
