- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Oil Leak
I Have Got Oil On The Bell Housing Some On The Driver Side Of The Block Above Thte Oil Pan And Oil Droplets On The Center Of The Engine Behind The Bottom Pulley Where That Angled Drain Plug Is. Does Anyone Have Thought About It, I Would Like A Little Heads Up Before I Go To The Dealer
Bukwakr |
| Sponsored Links |
Oil Leak
Oil leak
Ok shoot After reading all these leaks there, I crawled under my PSD. Hum, never found oil on the cement but I do have oil on the housing center front of transmission. I wiped it off. I could not see where oil ran down but on the front end mid of bell housig was about a 4" area with oil on it. WHat do you guys think? I just passed 3,000 miles.
Oil Leak
THank I did as you say. I agree.. I do not like having it messed with unless it must be. I did go back again after the post. The very front of the bell housing where it comes together. It may have run down both sides of the seem. I seem to see some traces but not sure. That front cover is a dust cover right? I would guess it came thru it. I seem to see some traces on both sides but they start only 1-2 inches on that seem. LOL but not any higher. It is like it ran down that seem on both sides and accumulated on the center of the bellhousing and stopped. I do think you are right at this point in time. I have seen these post for the past month. So i regularly checked my driveway for oil and to this point I do not have a single drop. S
a lot of times you will find some oil on the lowest corner of each head...and a little on the starter too with this "residual....meaning the factory was too lazy to clean it" oil........clean the bottom back corners of the heads and the starter too....or it will show back up agian....the stuff that is already in the bellhousing just takes time to come out.....Marc
oil leak
i had an oil; leak on my 05'f-250 stroker when i bought it new. dealer repaired it , it was the crank seal! jason
| Sponsored Links |
