low pressure fuel pump - Ford Powerstroke Diesel Forum
Old 09-08-2009, 05:09 PM
replace 3 pumps in 3 days still low pressure. help
Old 09-08-2009, 05:11 PM
duct tape & zip ties
Have you thought about dropping the tank. Inspecting the pick up assembly. There is a fuel sock on it that maybe clogged.
What is your fuel pressure.
Where you located in Michigan. If you are close by I can give you a hand.
Old 09-08-2009, 05:13 PM
Pressure Regulator?
Old 09-08-2009, 05:16 PM
Originally Posted by md18 View Post
Pressure Regulator?
That would be up by the engine. Which if he is checking fuel pressure after that then that could be giving a false reading.
But the fuel pump only puts out around 40psi anyways.
Old 09-08-2009, 05:22 PM
I did drop the tank ran air through the lines.The fuel pressure is 25 psi. I live in goodrich michigan.
Old 09-08-2009, 05:27 PM
You are 1.5 hours north of me.
Ok when you dropped the tank did you check the fuel sock in the tank. Did you clean the mixing chamber out that is in the tank.
Inside the tank on the pick up assembly. There is a fuel sock on the bottom of the pick up. Then about 8 inches up from that is a white canister. In that white canister is two fuel screens. They can and will get clogged up.
Also the fuel pick up is known for allowing the pump to suck air.
Now where are you checking fuel pressure at. Are you checking it at the pump some how. Or are you checking it from the shrader valve.
Send a message via Yahoo to chuckles
where are you checking fuel pressure at? Also to emlinate the tank, you could just use another container and plumb a pickup line into the HFCM. Then check pressure. Should be 56 psi at idle. Will the truck not start?
Old 09-08-2009, 05:36 PM
Thanks for the info.I will drop the tank again and recheck.
