Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
  #71 (permalink)
Old 11-01-2009, 06:11 AM
dxusmc dxusmc is offline
good to know before I started tearing the truck apart. ha thanks chan
  #72 (permalink)
Old 11-01-2009, 04:52 PM
LDH LDH is offline
Hey Chan, hope things are going good for you. I haven't been on here in awhile. I ended up removing the intake and EGR cooler on my truck shortly after I talked to you last. I cleaned all of the soot out of it and considered the EGR delete but decided against it for now. My truck has been hanging in there (still has a miss). My degas bottle developed a crack last week. I went out into the garage to change my fuel filters and when I crawled under to do the one on the frame, I noticed a big puddle of antifreeze. I traced it down and found that my degas bottle had a hairline crack on the underside. So, I replaced it and things seem normal again (other than the miss). In case anyone wants to know, the degas bottle was $65.
  #73 (permalink)
Old 11-01-2009, 06:31 PM
elm302 elm302 is offline
hey LDH
not to change the subject but did you get the heat induction flash or the whole new flash from for because i went to ford and they said they couldnt do just the ficm flash for the heat induction
  #74 (permalink)
Old 11-02-2009, 07:37 PM
LDH LDH is offline
I think they did everything, not just the heat induction.
