Last week I replaced my EGR. A week later it was running terrible. I showed a code for a bad ICP Sensor. I replaced it yesterday. Now the truck won't start. Now shows code for CPS. Could someone please help me find the location so I could start drive my truck? Thanks a lot!
cps location
passenger side front of engine below water pump pulley
Thanks a lot bro I appreciate it!
What's the easiest way to replace this? What's the best way to get to it and what do I need to remove to get at it?
unless you have a belly pan nothing to remove, look up from under truck toward water pump pulley. remove connector,using a 10 mm wrench or socket remove bolt from bracket attatched to sensor, twist and pull on sensor it should pop out if not pry on bracket. lube oring on new sensor push into place,install bolt and connector. no need to torque bolt just make it tight
I can't see it. Its between the balncer and wp pulley?I wish my truck wasn't on 37s and my arm wasn't so big.
look to the passenger side of the crank pulley
Found it. Replaced it. Ran really bad again. Still sayong bad crank sensor and icp.....
check the wiring harness for shorts.
