2004 6.0 - Ford Powerstroke Diesel Forum
Old 08-25-2009, 05:44 AM
Hey guys, new to the board and have a question. I have a 2004 6.0 diesel that has developed a flutter sound coming from the air box area under excelleration only while towing. I pull a 40' gooseneck probably around 13-14k lbs. and it only seems to do it around 65 mph or so while lugging on a hill or something. Any ideas?
Old 08-25-2009, 05:57 AM
are you seeing any boost loss or any power lose when this happens. my 04 had a throttle plate in it that was getting stuck and causing a noise and power loss. took it apart and removed the butterfly out of it and havent had a problem since
Old 08-25-2009, 06:06 AM
Power loss just while it's fluttering. I don't have a boost gauge, so I'm unsure about that. If I get into the gas pedal or let off it goes away and may not happen again for the rest of the trip. Thanks.
Old 08-25-2009, 09:37 AM
Feedback Score: 5 reviews
Turbo vanes are sticking..tpy problem with the 6.0. warrentee problem..get it in. They get a SCT with Cales tunes which cures 90% of this problem in the future.
Old 08-25-2009, 09:39 AM
Almostdunfukinwidit
I just want to point out that since the truck is an 04 he might be out of warranty due to the start date
Old 08-25-2009, 09:44 AM
could also be egr valve pull it out and see if its all plugged up if it is clean it and make sure its closed all the way install it and then forget to plug the harness into it. it wont throw a cel. if that stops it then next thing to do is do a egr cooler delete. then one less problem to worry about
Old 08-25-2009, 10:10 AM
try what purplehorn1977 said about tha egr i had the same problem try 2 get a boost gauge and see wut it does if it looses boost or anything and get a SCT tuner it will help my truck does it every now and then but i havent had the time to pull my turbo vanes to look at them ive been busy with my torque converter... send me a PM if u hear of anything else that u have found out i would like to know...
Old 08-25-2009, 10:54 AM
So will any of these problems throw fault codes? Haven't had any of those yet.
