05 F-350 died, Won't Start - Ford Powerstroke Diesel Forum
Old 08-24-2009, 11:17 PM
My 2005 F-350 just died tonight coming down a hill, like it ran out of fuel. Got her off the side of the road and checked what I could. Fuel in upper bowl, fuel cut-off switch good, fuel pump runs,fuses good. She cranks hard, just doesn't want to fire whatsoever. It was running fine up to that point. I pulled these codes from my edge programmer and there are 16 of them. I pulled the relay out to the PCM when I was looking at fuses, so I don't now if that triggered any of these codes.
P0261, P0264, P0267, P0270, P0273, P0275, P0276, P0279, P0282, P0528, P0606, P0611, P1378, P02290, U1055 and U0100.
From the reading I have been doing it sems that my FICM is toast. Can someone steer me in the right direction for troubleshooting this thing. In the morning I will check the STC fitting and see if there is oil leaking.
Thanks - Jeff
Old 08-25-2009, 12:17 AM
Tennessee Powerstrokes
I was going to say check the oil in the HPOP. These motors are set up to shutdown if the oil gets too low. Hope this helps.
Old 11-21-2009, 09:24 AM
sounds like hpop to me also ,did it just quit or did you notice a little loss of power before it died
