03 OIL Temp Problem.
I have an 03 f250 i am haveing a little bit of a problem with the oil temp. Befor i changed my oil my temps where staying about 17 to 18 apart in on the highway. and in town they where staying about 12 to 14 not since i changed my oil it stays about 14 to 15 on the highway and 8 to 10 in town am i going to need to replace the OIL cooler. please help
thanks |
I'm not sure what those numbers mean. 17 to 18 what?
Degrees sorry i am talking about the engane oil time and the engane colant temp ford says that they should not be more than 15 degrees aprt
Is there no one out ther that can help me. my engian oil temp is running to hot and i need to know what to do.
how many degrees diffrence is it suppost to be, because i forget ...i had to have mine changed because of the same reason but i forgot the degree's they should be apart.......hahaha damn its early the answer was right in front of me ...sorry ....well you might have to change it out ....they do get plugged and it doesnt allow the coolent to flow proper witch makes the oil hotter
Dose any one know where the oil cooler is and how hard it is to change out
its on top of the motor under your egr cooler
15* difference between oil and coolant
Dude, if your temperature difference is only 8 - 10 degrees in the city, and 14 - 15 on the highway, then there's nothing wrong. Ford's spec is for a MAXIMUM difference. 10 degrees is less than 15 degrees, so you're on the safe side.
