a.c blowing out of my defrost only? help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-21-2009, 06:30 AM Thread Starter
My sofl seems to be working ok and I have checked for vacum leaks when i turn the and listen under the hood to see if i can hear the vacum pump I hear nothing. If vacum pump is bad would my 4x4 still work
tcslawnandland is offline
post #2 of 4 Old 08-21-2009, 06:38 AM
dbkerley's Avatar
Put a gauge on it and see how much you are pulling. If you are showing vacuum, hook up a pump to the control lines and be sure the actuators are functioning. I'm not sure about the 4x4 question though.
Brad
dbkerley is offline
post #3 of 4 Old 08-21-2009, 06:41 AM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
same thing happened to me Wednesday, The vacum pump took a dump and had to be replaced
Mike
"The Iron Pig"
mudrunninpig is offline
post #4 of 4 Old 08-21-2009, 07:53 PM
mine did the same thing a couple weeks ago.
check the actuator solinoid on the left side of the intake mani, make sure the 1/4 line is still connected.
6-ohPonyhaulR is offline
