Crank but no start
I have searched about this and have a lot of useful information. Just wanted to start a new thread about one issue that might add to my problem. I'll start from the begginning.
Just bought an 06 F350 King Ranch CCLB 4X4 with 113,000 miles. I have driven it a lot and has been running great before I bought it. It was low on fuel so I rode with a guy from the dealer, which I too work for, and put 32 gallons of diesel in. Yes it was diesel. drove 3 miles back to the dealer shut it off for about 10 minutes to do some final cleaning before I left. Drove 5 miles to the DMV and came out 30 minutes later and it will crank but won't start. I still have to hook a GOOD diag tool to it to get certain info. What I am wondering is what problems could the fuel that I just put in give me? It ran great up until that point. No sputtering or smoking or anything. Plus I only paid 17,700 for this truck and I think its a deal. What can you guys tell me? I have 4 days to return it if it is something major. Thanks in advance, Nick |
The most common thing to cause a problem like yours is the FICM. I am not saying that is whats the problem but it is very common. You need a good scanner to hook to your truck to know for sure.
I will have a matco determinator in the morning. It reads everything I need to know. Just pissed right now and want to know what's wrong right now, but I know that aint gonna happen with out the scanner.
How much does the FICM run? |
$900 +/- When mine went it it was a total of $1200 for tow,ficm, labor
Does it need to be programed or is it just plug and play? I can get parts at wholesale prices from ford dealer so I may be able to do it myself. If that's what's wrong.
Thanks, Nick |
It has to be programmed by Ford and thats the only problem. Getting to it and changing would be easy but then you would still have to get it to ford.
I don't guess that would be so bad. Right now it has to be towed anywhere no matter what. I could install it and then tow it to ford. That would save me a little change.
Now I just have to wait for the morning to see what the actual problem is. Thanks |
I know first hand its a common problem. Our 6.0 died at 110,000 miles. It was the FICM, but it also needed the cold flash. Did it idle real rough in the mornings?
I haven't experienced any problems or symptoms the little bit that I drove it.
codes
V0306- software incompatibility with fuel injector control module P0487- EGR throtle position control circuit P01000-OBD2 monitor/drive cycle not complete RPM while cranking with now low batteries 118RPM. ICP-3.4 PSI ICP Desire-1198.52 PSI ICP Volt- .25v IPR duty cycle- 85 percent Cleared the codes and still have the same problem. Can anyone help me? |
