6.0 smoking and loss of power - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-18-2009, 07:05 PM Thread Starter
I have a 04 6.0 i could be riding down the road and it will just start smoking black smoke and loose power i let off the gas and its like it fixes itself i get back on it and it runs fine. It doesnt do it all the time sometimes it wont do it for a week but sometimes it will do it 2 to 3 times in 10 min. Please help if eanybody might no my problem.
bblancha is offline
post #2 of 6 Old 08-18-2009, 07:07 PM
ajpu1983's Avatar
Sounds like a possible EGR valve or turbo acting up.
ajpu1983 is offline
post #3 of 6 Old 08-18-2009, 10:53 PM
durawut's Avatar
I second that had the same problem with my 05 6.0 egr valve sticking and turbo needed cleaned. the reason for the black smoke is lack of air for a complete burn ie. egr valve/turbo problems... GL
durawut is offline
post #4 of 6 Old 08-18-2009, 11:46 PM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Pull your EGR and see if its stuck open. That can cause black smoke.
Also Turbo Veiens stuck open can cause black smoke. But pull the EGR first.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #5 of 6 Old 08-19-2009, 04:29 AM Thread Starter
Will it mess up eanything by me pulling the EGR valve or do i just pull it off clean it and put it back on.
bblancha is offline
post #6 of 6 Old 08-19-2009, 05:39 AM
Chapter Director
psd_va's Avatar
yea just pull it clean and reinstall but make sure you don't damage one of the seals and don't hold it upside down and spray it with anything you don't want any chemicals to get in the upper part of the valve from what i hear
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
