06 6.0 nightmare - Ford Powerstroke Diesel Forum
Old 08-18-2009, 11:20 AM
06 6.0 nightmare
06 6.0 will not start when it gets to running temp.I was tolod about oil rail plugs or hpop?Any ideas
Old 08-18-2009, 11:27 AM
the stc fittings if not changed can cause this also oil rail orings can cause this if its under warrenty id be seeing the stealership.
Old 08-18-2009, 11:28 AM
wait...are you yanni the famous greek singer?
Old 08-18-2009, 11:38 AM
THREE POSTS and we are off-topic.... we are getting worse (or maybe better) at this.
OP: There are o-rings in your High Pressure Oil Pump (HPOP) and related lines. If you aren't familiar with the super duty fuel systems, they use high pressure oil to actuate the injectors. (search and you can find more detailed info here) These o-rings can become weak or damaged and may leak only at operating temp or when cold or only at a specific time, causing a no run condition as the injectors will not fire properly without this oil pressure. And, there was a test fitting (?) on them that was bad about failing but I believe that will cause a no start condition all together not a temperature dependent issue.
And yes, purplehorn is correct, if you still are under warranty (5yr 100,000mi engine) Which you should be, take it in and let em fix her for ya! good luck
