P0278 Cylinder 6 Contribution/Balance Fault
Does anyone have any addtional information for this fault code or know of where I can find some possible causes for this fault?
Found this code on my Edge unit today, wondering if there is a plug or injector issue w/#6? Thanks for the help guys. |
As long
as a rocker didnt come off its prob a injector. Do you have an after market air intake or anything?
Stock intake on the truck. Aftermarket one is here at the house, just need the time to install it.
I supposedly have this same prob w/ cylender #4. MY cousin is a diesel helper and he said its probly a miss fire. I havent felt anything out of the norm but he said chances are you wont, you might just lose some power.
u guys get anywhere on this issue?? i have one for cyl #1 and have felt a stumble at idle sometimes?? also on my edge monitor every once in a while the egt hits 1400 for a split second just enough to set off the alarm set at 1250 but u gotta be waatchin the monitor or ull miss it its so quick..im hopin its not an injector but when i clear it it comes back in a couple days..im prob gonto change the oil and see if that might take care of it.
anyone else have a clue??
Haven't done anything with this yet, I just got a P0336 and a P0341.
For the crank and Cam sensors, truck started sputtering at about 2500rpm. Going to call the dealership tomorrow and take it in. |
