I have an 03 F250 fuel leak that manifest only on cold engine start up. Fuel drips at the back of the engine/bell housing area.It's more than likely coming from above. I took it to the dealer under 100K warranty and left it for a week. The repair order stated that they found the leak with a blacklight and replaced the cam-sensor. Didn't help.This is a serious leak,which covers an area of about 4' in 15 min. I think it's the injection pump. Any ideas? Thanks Dan
I don't have an answer for you but
to Powerstroke.org. Someone will be along to help you out.
I seem to be getting the same leak now that the dealer has "Fixed" my oil leaks by replacing the charge air cooler duct, and then on the second try the cam sensor. Now I have "green stuff" leaking around the bell housing. It is not bad yet, but I will get it checked. Anyone have a clue whats up? Thanks!
