Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 07-03-2009, 03:10 PM
mikehock mikehock is offline
Head Gasket/Oil Cooler Replacement
I finally figured out that the problem with my truck is either the head gaskets need replaced or the oil cooler needs replaced. I am planning on replacing both the head gaskets and oil cooler and deleting my egr and egr cooler in the process. Does anyone know where I can find a step by step manual on these progects and also do you have any advise that may help me? Thanks.
Old 07-04-2009, 12:11 PM
mikeproc mikeproc is offline
if you know someone with all data, or buy a factory manual. Its not very bad, Im doing it right now and have posted a bunch of pics and a little write up.
