Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 05-03-2009, 03:57 PM
kingranch62085 kingranch62085 is offline
help with truck stuck in 4low
I have a 06 f250 diesel and the other day I was in my shop i put it in 4 low and built it up because my friend wanted to hear what it sounded like and when i was all done i tryed to put it back in 2wd and nothing i did all the usual put it in n with truck idlin and foot on and off the break backin up goin up and down my lane still nothing anyone have any idea to what in the world is goin on
Old 05-03-2009, 09:23 PM
ZMANN ZMANN is offline
it's bound up but the reverse trick should work??
Old 05-03-2009, 09:29 PM
Clay Henry Clay Henry is online now
Sooner Powerstroker Mod
keep trying...Put the tranny in N, shift it out of 4 low. Then back up down the drive or road a few feet.
Old 05-03-2009, 09:48 PM
Goose350 Goose350 is offline
Obamacare..
I had this problem one day. I just kept messing with it and it finally came out.
Old 05-04-2009, 10:18 AM
Thanks guys for all the help but i have been trying to get it out all moring long buy doin the same thing backed up for a long while still nothing anyone have any other suggestion maybe the motor is lock up or something??
Thanks for the inputs ever little bit helps!!
Old 05-07-2009, 06:37 PM
well the transfer case would unlock and the pump actuated hubs should unlock I am not sure whats up? first time I locked mine in I thought I would be driving home in 2 low lol but it came out in revers finally
Old 05-07-2009, 06:39 PM
2005F250 2005F250 is offline
Try going foward?
Old 05-07-2009, 06:40 PM
raveer2000 raveer2000 is offline
Resident Tire Smoker
I drove mine about 1/4 mile in low once because it was stuck.. Eventually it shifted back to high.
Old 05-12-2009, 04:02 PM
kwatson kwatson is offline
im on my second encoder motor now. Pickup has 61000 miles. stuck in 4-low and wont come out no matter what. ended up taking motor assembly off and turning out manually. would still go to 4 hi fine but not 4 lo
Old 11-01-2009, 05:00 PM
6.0Lpowerstroker 6.0Lpowerstroker is offline
Unhappy same prob
i had the exact same problem. i was driving down the road (2wd), and pulled over for a minute, everything was fine. then to get back on the road i had to splash through some mud. so i switched to 4hi on my shift on the fly, then got through the mud, and when i switched back to 2wd, the 4x4 light stayed on. i thought, eh,....its a glitch, no biggie. it stayed on the whole way home, it was all freeway driving too, anywho,.... got home just fine, and decided to mess with it. my brilliant buddy sugessted go to 4lo and then back up to 2wd. now its stuck in 4lo and and all it wants to do is crawl up the side of a damn house!!!! or tear the axels off some chevys!!! any thoughts? or experiances? i read somewhere else it was a 4x4 circut board issue. possibly got wet and fried, or the seal gasket was rotted, and the circut was wet. any help pls!!! im lost.
