Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 01-23-2007, 01:48 PM
2006PSDSD 2006PSDSD is offline
ΜΟΛΩΝ ΛΑΒΕ
My F-350 death wobble fixed?
I just got my truck back from the dealer for the third time for the death wobble. I think that they have fixed it . It still does it a little, but I don't think its any different than my F-150. Here's what they did: in addition to the TSB available from Ford, changed my caster angle in the front end to
Right
before 2.0
after 1.5
Left
before 1.9
after 1.4
Old 01-23-2007, 02:22 PM
andylant andylant is offline
Send a message via Yahoo to andylant
I've got an '06 250 with the 6 liter... When getting up to 65 mph it feels like my right front end is wobbling. I know it's not the alignment or the tires because I just got some new tires put on with the alignment about a week ago.
Old 01-23-2007, 02:32 PM
ΜΟΛΩΝ ΛΑΒΕ
I would take it back to the place that installed the tires and have them do a road force test on your tires. Did this happen before the tires and alignment?
Old 01-24-2007, 01:37 PM
It kinda did it with the stock tires too... I think that with the stock tires it actually started to wobble at 60 mph.
Old 01-24-2007, 01:42 PM
ΜΟΛΩΝ ΛΑΒΕ
Still could be a road force issue. Road force is like a flat or uneven part of the tire, that can usually be phase matched to the rim. Take it to whoever installed the tires and tell them to do a road force balance. If they don't have the machine to do so, take it to discount tire and have them do it.
Old 01-24-2007, 09:24 PM
What's the difference between that and balancing?
A better question would be, what is done differently from the balancing machine?
Old 01-25-2007, 07:33 AM
ΜΟΛΩΝ ΛΑΒΕ
It's actually built into the balancer. It is a roller that presses against the tire tread, to get a measurement of road force (explained earlier). Call a tire shop and ask them if their machine has the capability, preferably the one that installed the tires. Hope that helps.
Old 01-25-2007, 10:30 AM
Evil Eye Evil Eye is offline
Slacker Mod
If it is worse now, you likely have a tire/rim problem and you should have that checked. Also, you should check out your steering stabilizer. My truck had a pronounced shake upwards of 60mph and it turned out to be the stabilizer.
